If you find one, use 'em quick because they won't be around long. Milling is no worry with mag, but those long thin stringy chips from turning go "whoosh !" like you wouldn't believe and I don't know how you'd keep a swiss totally clear of chips. I guess if you budgeted for a new machine and building every six months you could do it ....Does anyone know of a swiss shop that will make magnesium parts?
Ehh. I didn't machine tons of the stuff, but I found it really enjoyable to run. It's like a lightweight Mic6. 1/2" 3 flute at 12k RPM with no worries. I tried to light some chips on fire with a cigarette lighter with no luck, but I still had a type D fire extinguisher and 5 gallons of kiln dried sand at the mill.How big is the risk of catching fire really, if tools are kept sharp and the swarf cleaned out often?
Milling != turning. Even if you are turning and get absolutely nothing but 6's and 9's, you are fine (clean. Clean clean clean, don't let them accumulate !) but lathes do not always break chips. Even if they do, when you run up to a corner and change directions to face out, or even just run to a corner and pull the tool out, there's a fine little stringy long chip that you get, like a long blonde hair. Those guys go off in an instant and they'll set off the 6's and 9's much better than a lighter.1/2" 3 flute at 12k RPM with no worries. I tried to light some chips on fire with a cigarette lighter with no luck, but I still had a type D fire extinguisher and 5 gallons of kiln dried sand at the mill.
How about getting it centreless ground (those boys know how to handle such material) and sawing it to length - or are the parts more complicated.It is AZ60A magnesium alloy. These are .125" diameter pins. Is there a better way to make them? I thought maybe grinding but magnesium dust sounds worse.
Meaning water-based coolant I assume, because magnesium can burn underwater, stealing the needed oxygen from the water, releasing hydrogen gas.It was great until I learned that if you leave mag chips in the coolant, it somehow turns to salt water or some shit and you have to dump the entire sump, clean the system and recharge.
If the lathe was in your garage at home, would you take the job ?Many years ago I turned a bunch of magnesium parts in a CNC lathe. We emptied the water based coolant and filled it with mineral oil. (Sunnen honing oil)
Didn't have any problems.
I never used it since that mag job went away, but Oemeta has a mag-specific additive for their two part coolant.Many years ago I turned a bunch of magnesium parts in a CNC lathe. We emptied the water based coolant and filled it with mineral oil. (Sunnen honing oil)
Notice
