Overland
- Nov 19, 2017
- Greenville, SC
The gearbox is disassembled now. The grinder is a drum with teeth on it that cut against an anvil, I believe. Apparently PLC controlled; the PLC senses load and auto reverses to protect system. Obviously something dropped in and stalled the grinder.Some good suggestions here some bad. Drilling out a captured key is ridiculous . The shaft is extensive, having a grinding element past the bearing and the whole thing in some sort of housing .
Does the customer want repairs done in place or tear down?
I would bar over the grinder and measure run out of gear now.
I would advise that in place removal will likely leave shaft in an unusable as is condition, requiring a time consuming and expensive in place repair of the fit for the gear.
Typically a grinder like I think you’re talking about will have circuit protection to kick out the motor in a jam and require an Operator to reset and manually hit reverse to clear.
If this is a hammer- mill, more often seen handling scrap wood and metal, it may well be a tapered fit for the gear.
I really need more info on the problem, Will it not run as is?
It might be possible to just reassemble the gearbox and run it. Would need to ensure this shaft is running true first, and be sure no other damage.
If everything is running true this might be a viable option. However, the system will reverse from time to time, so there is a concern the gear may move on the shaft.
The PLC control system can probably be programmed to run slow speed in reverse and limit torque, assuming VFD's etc. I doubt there is much risk of the gear moving on the shaft.
Bob
